Mal P
- Mar 17, 2000
Hi there,
My receiver has a fixed crossover of 100hz, and I'm led to believe that this is too high. I was thinking about adding the Outlaw ICBM to handle the bass management. Do you think it will work in the way it's described as follows:
1) My L/R speakers handle bass down to 31hz at -3dB. The center handles 50hz at -3dB and the rears 55hz at -3dB.
2) The speakers will be connected to the receivers speaker-level outputs as per normal.
3) I'll set all speakers to "Large" and the subwoofer to "On".
4) I'll take the 5.1 pre-outputs on my receiver and plug them into the ICBM's 5.1 inputs.
5) On the ICBM, I'll set the L/R crossover to 40hz, the center crossover to 60hz and the rear crossover to 80hz.
6) I'll take the subwoofer output from the ICBM and plug it into my subwoofer, which is dialled to it's maximum crossover level.
Do you think this will work, i.e. adding an external bass management unit? This way, I won't have to upgrade the receiver (instead I can buy a good two channel amp!) and I'll still be able to use the maximum bass capabilities of my speakers.
Mal
Mal
