Dodie
- Nov 1, 2002
Can I use RG6 Cables as component cables? If that is possible are there connectors available in the market so that i can use this (RG6) as component cables?
FYI:
CATV signals stop below about 1 Mhz
Component Video tops out at about 4 Mhz
Progressive Video tops out at 12 Mhz
True HD video tops out at 35 Mhz
So do you really want to use outdoor-rated CATV coax and generic RCA plugs for your video cables?
I don't really understand your point. What I call "regular RG6" (i.e. the stuff used for most satellite dish intallations) is rated for video signals up to 2.2 GHz, WAY more than is needed for HD video. Here is an example of RG6 that I am talking about. You stated "HD rated video coax sells for about $1.50 /ft ". AFAIK the primary difference between this and the .20/ft cable referenced in the above link is fexibility.
Regular RG6 cable with proper connectors/adapters can be used for many kinds of HT cables including:
1. Composite video
2. Component video (3 runs)
3. S-video (2 runs with adapter)
4. Analog audio
5. Digital (SPDIF) audio
6. Subwoofer cable
7. and obviously OTA/CATV/Satellite RF cable
I have used RG6 with crimp-on F connectors and RCA to F adapters for all of the above uses except #2 and #3. I have no reason to believe that RG6 would not work just fine for those uses.
Jay
The 2.2GHz cable is specially designed to carry high-frequency signals, so you will get maximum signal strength! The cable is constructed of an 18-gauge solid bare copper conductor with foil and braid shielding to provide protection from electrical noise
