Can I use my old Polks as rear surrounds with new Paradigm main/cc?
Discussion in 'Speakers' started by michael_mo, Aug 8, 2003.
  1. michael_mo
    michael_mo Stunt Coordinator
    Jul 29, 2003
    81
    I have Polk monitor 7c, about 15 years old. Still sound good. I plan to get Paradigm monitor 7 with the CC370 or (if i get a good deal) studio 60 v2 with the matching studio CC.
    Can I use those polks in the back, at least temporarily till I can fill up the piggy bank again and get a good set of di/bipole paradigms??
    Mike / Ohio
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    Of course you can. I have no idea how close in timbre they are to the digms, but it should work wonderfully. Ideally you'd want to match all the way around, but as a temprorary (or even permanent) solution, it should work fine.
  3. greg baker
    greg baker Stunt Coordinator
    Feb 13, 2003
    165
    I think that combo would be fine. I think that the Timbre matching would be much more important for the front and center though I think it is a bit over rated
  4. Bhagi Katbamna
    Bhagi Katbamna Supporting Actor
    Jun 1, 2000
    870
    Timbre matching the front and center is important but not as easy as buying the speakers from the same manufacturer. Even if they have the same woofer(s) and tweeter. The location and the fact that the center may be on top of the TV is something that takes away from timbre matching.
