Can I upgrade my Sony towers or Bostons?
Discussion in 'Home Theater Projects' started by Jesse Sharrow, Mar 3, 2004.
  1. Jesse Sharrow
    Jesse Sharrow Supporting Actor
    Jul 11, 2003
    745
    I am just starting to get into DIY. Well I havnt done anything yet but you get the point. I was wondering. I have a pair of sony towers. 6 1/2", 4", and tweet in a very resonant, ported tower enclosure. They sound like crap. But they are just surrounds for now. Now is there anything I can do to make them better? Brace the enclosure? Sound deadening material? What about upgrade the drivers? If I can do something to help I would be willing to look into it. What about just using a better crossover?
    Well Ill shut up. Thanks for the help.
  2. Rory Buszka
    Rory Buszka Supporting Actor
    Jun 5, 2002
    784
    There is probably not much you can do to the Sonys. A better crossover would help, but there is an insane amount of development that has to go into a crossover. In addition, bracing that you would add would lessen the internal volume of air in the speaker cabinet and the bass wouldn't extend as deep (not that it does already, probably). I would say start saving spare change for a new and better set of speakers. Or, if you're a woodworker, save up and build one of the many project speakers that are out there on the web.
  3. Jesse Sharrow
    Jul 11, 2003
    745
    Ok thats kinda what I thought. Now could I build a center channel to match my Boston VR-950's?
