Can i turn Cat5e into S-video, PS/2, 3.5mm audio cables?
Discussion in 'Beginners, General Questions' started by matt steele, Apr 14, 2004.
  1. matt steele
    matt steele Extra
    Nov 19, 2003
    19
    I am trying to hook my reciever up to my computer which is in another room. I also want to be able to control my computer from where the reciever is by using my tv as a monitor. The cables i will need are:
    S-video
    To use my tv as a second computer monitor
    PS/2 cable.
    To run a second mouse
    3.5mm male to femal connector
    Running from audio output on computer.
    3.5mm male end to 2 rca male ends.
    so that i can connect the 3.5mm cable to my reciever.
    Is it possible to make all these cables out of cat5e? This may just not be possible. Im just wondering. If it is cam some one let me know how?
    If this isnt possible anyone know a place that sells all this stuff on the internet. I dont want any high quality BS cables that cost $200. Most these need to be 15 feet long. I feel cheap stuff will be fine.
  2. Chris Moe
    Chris Moe Screenwriter
    Jun 12, 2002
    1,087
