Brett DiMichele
- Sep 30, 2001
- Brett
Okay before you say NO listen to what I have to say
My Center channel is THE EXACT same C-T-C MTM with all
drivers mounted flush with the baffel and the baffel is
the same size as my towers.. Everything is exactly identical..
But..... The crossover in my Center lowpasses the mids at
70Hz. The XO in my mains Lowpasses the Mids at 100hz..
My mains take over from 100 down with the 10" subs..
My center sounds more impactful.. Because it's playing
lower..
So could I take my center channel's XO and write down the
ingreedients and build a pair of XO's for my mains with
GOOD parts on boards.. And lowpass the mids at 70Hz and
just do away with the crossover for the subs period since
my sub amp has a variable XO from 120 down to 40..
The simple answer should be "Yep" right?
I can't see any reason not to.. The mids have tons of
excursion and in thier curent configuration they don't
even move... (well they don't move much..)
lower..
