Can I put A/V-1's in this enclosure?
Discussion in 'Home Theater Projects' started by ArthurJ, Nov 29, 2003.
  1. ArthurJ
    ArthurJ Second Unit
    Jan 29, 2003
    354
  2. Joseph Sabato
    Joseph Sabato Stunt Coordinator
    Sep 13, 2003
    67
    Arthur
    I would go to the next size up in the catalog; the .38 cu ft enclosure.
    Just based on external dimensions, The AV1 enclosure is 1128 cu inches; the enclosure you asked about is 900 cu inches and the .38 cu ft enclosure is 1176 cu inches. Since the PE enclosures have a brace in the middle that frames the enclosure ( and I have no doubt that the GR enclosure does also) the .38 cu ft enclosure will be pretty close, and can be made "smaller" if necessary by glueing in some MDF if necessary.
  3. Joey Skinner
    Joey Skinner Second Unit
    Sep 12, 2003
    339
    The AV1 has a port also.
