Can I plug the port on my PB-10?
Discussion in 'Speakers & Subwoofers' started by EdNichols, Mar 15, 2005.
  1. EdNichols
    EdNichols Second Unit
    Feb 15, 2003
    372
    I understand that plugging a couple ports on the bigger SVS's make a difference but what about plugging all ports or in my case with the PB-10 plugging the only port. Will it hurt anything? Can I expect it to sound "tighter" like the sealed subs are supposed to sound?
    If it is OK to do, what would be a good plug to use? I guess I would have to make one?
  2. JasonCI
    JasonCI Stunt Coordinator
    Dec 29, 2004
    59
    It's OK to do. I think Ilkka, a HTF member, tried it and wrote about his results. Just use anything you've got around the house to plug it and see if you like it. If your results are positive I'm sure you can find a foam plug somewhere on the net.
  3. EdNichols
    Feb 15, 2003
    372
    I tried doing a search before I posted but didn't find anything under the topic. I also tried searching under Ilkka and found some stuff but nothing on plugging a PB-10.
  4. Ilkka R
    Ilkka R Second Unit
    May 19, 2004
    270
  5. RyanJE
    RyanJE Second Unit
    Jan 5, 2005
    438
    NO! Youre not allowed! [​IMG]
