Can I plug my powerred sub into the outlet in my receiver.
Discussion in 'Archived Threads 2001-2004' started by John Berggren, Feb 5, 2002.
  1. John Berggren
    John Berggren Producer
    Jun 17, 1999
    3,238
    Basically what the question says. The guide specifies not to plug your television into it, but nothing about any other peice of equipment. I find that I'm leaving my sub powerred on after use, and I'd like it to turn off automatically with my receiver.
    Thoughts?
  2. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    I would avoid doing it if at all possible. I think any amplifier or powered subwoofer would draw too much current through this connection. But then again, I never use these "piggyback" AC connections for any device in the first place, so maybe I am the wrong person to answer this question.
    Michael
  3. MarcVH
    MarcVH Second Unit
    Dec 26, 2001
    324
    I don't know if it's typical, but my TV (32" Toshiba) draws about 150 watts according to the manual. I suspect your subwoofer draws that much (or more.)
    Those outlets are generally intended for things like tape decks or CD players, not amplifiers.
  4. John Berggren
    Jun 17, 1999
    3,238
    I had a feeling that would be the case. I'll just have to learn to remember to turn it off.
  5. Craig Morris
    Craig Morris Stunt Coordinator
    Oct 10, 1998
    195
    Absolutely do NOT use it. Every receiver I've owned has been very clear in the user's manual. Those outlets are for accessories and source components only. They are not rated to power demanding devices like amplifiers and I don't think you want to experiment with it, unless you're a pyromaniac. [​IMG]
  6. Michael Mohrmann
    Dec 30, 2001
    1,394
    Depending on the subwoofer you have, even when "powered on", it will go into a standby, low-power mode after a period of inactivity. Most people just leave these types of subwoofers powered on.
    If your receiver has 12V trigger outputs available, you could trigger a power strip (like a Panamax) that could power on and off anything connected to it. Some people have opted for this solution.
    Michael
  7. James Edward
    James Edward Supporting Actor
    May 1, 2000
    855
    No
