Can I Play DVD-Audio?
Discussion in 'Playback Devices' started by James Sarno, Dec 3, 2003.
  1. James Sarno
    James Sarno Stunt Coordinator
    Sep 23, 2003
    138
    Quick question...
    My Mitsubishi 8020 can do DVD-Audio,But my HK AVR110 does not have the analog imputs for DVD-Audio...
    Can I still play it ?
  2. Heath_E
    Heath_E Stunt Coordinator
    Mar 27, 2001
    157
    No. Well, you could play it but you won't hear it. You will need a receiver that has the analog inputs.
  3. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    You could play 2channel content which will offer much greater resolution than standard CD, but you need analog inputs for all channels to do multi-channel dvd-a.
  4. Steve_AS
    Steve_AS Second Unit
    Feb 4, 2002
    412
  5. James Sarno
    Sep 23, 2003
    138
    Steve,
    Thanks for the info...
    I'm going to go the 2 channel route and axcess my player's menu...see what I come up with...
  6. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    You'll want to check the disc's setup as well as your player, and set them for 2ch tracks. If you have only the multi-channel analog outputs on the player, as mine does (no stereo only output), you will use the main L&R outputs, and if your player defaults to multi-channel tracks, your sound will be missing information.
  7. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
    As has been said, you will not be able to play the Advanced Resolution Surround/Stereo from the DVD-A discs without the multi channel audio inputs on your receiver.
    Depending on the source disc it may also have the following which would be playable as 2 channel stereo or 5.1 surround via the digital connection to your receiver:
    2ch Stereo (DVD Video compatible)
    Dolby Digital 5.1 surround (DVD video compatible)
    dts 5.1 surround (DVD-V compatible, requires dts decoder)
    As an example, here are some discs I have and the content:
    Queen - A Night At The Opera
    Advanced Resolution 5.1 Surround for DVD-A
    Advanced Resolution Stereo for DVD-A
    dts 5.1 Surround for DVD-V
    Standard Stereo for DVD-V
    Emerson Lake & Palmer - Brain Salad Surgery
    Dolby Digital 5.1 Surround for DVD-V
    Chicago - Chicago
    BB King & Eric Clapton - Riding With The King
    etc etc
    The bottom line is you may be able to enjoy dts and/or Dolby Digital 5.1 surround with your current set-up.
    Note that you may have to set the output of your DVD player to DVD Video and leave the Multi channel off. On my Panasonic RP-82 I have to manually change to DVD-V (from DVD-A) in order for the unit to recognise the DVD-V tracks.
    Check the packaging of the discs to find out what kind of encoding is on them.
  8. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
  9. PaulT
    Oct 28, 2002
    932
    Yes, I stand corrected, I skipped over your post John [​IMG]. Advanced Resolution Stereo is available from the front L/R out of the DVD player into a spare 2 Ch analog input of the receiver.
    As I posted, some 2ch Stereo may also be available from the Digital output of the DVD player depending on the disc.
