Can I or can't I? Just don't like this woody design.
Sep 30, 2002 #1 of 3 Stasulos Stunt Coordinator Joined Sep 9, 2002 Messages 50 Can I or can't I? Just don't like this woody design.
Sep 30, 2002 #2 of 3 Dustin B Senior HTF Member Joined Mar 10, 2001 Messages 3,126 As long as you remove the drivers and binding posts first won't hurt any thing. Binding posts you might get away with just taping over, but I wouldn't want to try and tape over the drivers, would be simpler to just remove them.
Sep 30, 2002 #3 of 3 Brian Bunge Senior HTF Member Joined Sep 11, 2000 Messages 3,716 Make sure you sand them first as well. If there's some sort of poly, varnish, lacquer, etc. on the cabinets then paint won't stick very well. Brian
