hellspawn69
- May 23, 2011
- Josh
My Crown XLS1000 has a sensitivity of 1.4Vrms
http://rdn.harmanpro.com/product_documents/documents/2563_1431033281/XLS_Install_DataSheet_Web_050615_original.pdf
I'm wiring a Rockustics BP Sub Jr into my outdoor setup.
http://www.rockustics.com/products/subwoofer-series/bp-sub-jr/
It has (2) 4ohm 10" speakers. So I am planning on wiring each 10" driver to a channel on the amp.
I am pushing audio to my Crown XLS1000 via my Sony DA4600ES, currently planning on just using the SUB OUT on the receiver, and doing a Y-Splitter of the RCA cable so it can go to my Indoor and my Outdoor Sub. I already have the 2 channels I have for the SPEAKER B outputs on the DA4600ES going outside to my existing outdoor speakers, but I have verified the SUB OUT has signal flowing through it on SPEAKER A or SPEAKER B setting.
My question is, how can I verify my receiver is putting out 1.4Vrms? My (very limited) understanding is, I need that level (or higher, or is it bad to go higher?) going into the Crown XLS1000 in order to achieve it's maximum power.
I have a multimeter (although I'm a noob with it), if that can be used to take measurements.
Thanks!
Thanks!
