Can I make an SVS Boomy
Discussion in 'Speakers' started by James^Brian, Jan 13, 2004.
  1. James^Brian
    James^Brian Agent
    Mar 29, 2003
    29
    I'm thinking about buying an SVS (PB2+) for my garage I'm converting to a home theater. Yes, I know, the flat response is what makes SVS a step (or two or three) above most other subs. But if I want to crank up the volume on some hip hop etc---
    a) Will I be able to tune the sub accordingly to get "boomier" on some music and flat all the other time?
    b) Is there a difference between Box or Cylinder Subs in that one is easier to adjust the tune?
    c) Would any of the equipment they sell like the equalizer help me achieve this?
  2. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    Eh - I'd imagine you would just adjust the gain control way higher than normal.
  3. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    With an equalizer, you could probably phaten the bass in the 50-150 Hz. range. Because this is not where the excusrion is happening, and because SVS woofers are hella tough, it should be fine. Something to throw out - should it work?
  4. WayneO
    WayneO Supporting Actor
    Nov 10, 2003
    625
    I don't know if boomy is the right word, but you can make it pound by turning up the GAIN when you need to, that's what I do for the parties. One thing I'll mention is if your listening to the popular rap/club/dance stuff you might be suprised how low that stuff doesn't go. Even with my speakers set to "small" on my receiver for an 80hz crossover, there isn't a whole lot going to the sub with many songs. I jack up the output signal 12db or so and the drivers still ain't movin much. But when a song can lay it down, you'll definately know. You might try the high-pass speaker inputs and use the built in cross-over at 120hz to get the sub to do a little more duty. Simple knobs to turn for either style sub.
  5. Glenn Baumann
    Glenn Baumann Stunt Coordinator
    Mar 31, 1999
    100
    Yes, you can accentuate or diminish any frequency you like by utilizing an equalizer in your subs signal chain. I would recommend a parametric EQ as you can be very precise as to which frequencies you want to effect and by how much.
    Do a search under "BFD" ( Behringer Feedback Destroyer) and you will find a wealth of information. These units go for around $120.00 and can be VERY effective!
    Glenn
  6. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    Running it w/ all 3 ports open would also increase the output and the punch a bit.
