Can I hook up 2 subwoofers
Discussion in 'Archived Threads 2001-2004' started by AllanW, Nov 24, 2001.
  1. AllanW
    AllanW Extra
    Nov 2, 2000
    15
    Hi,
    I have the Denon 3802 and the Energy Encore Speakers system, and I was wonder if it was possible to hook up an additional sub. I am using the low level (RCA) connection to the sub. Can I split this? Or is there another way?
    Allan
  2. Vince Chan
    Vince Chan Stunt Coordinator
    Aug 22, 2001
    110
    Yes you can split the signal from one sub pre-out into two subs. Just make sure you use a high quality y-adapter to minimize loss of signal.
    -Vince
  3. Bill Cowmeadow
    Bill Cowmeadow Second Unit
    May 5, 1999
    404
    Go ahead and split the RCA Sub out. I do it as do many of the people here. Not a problem.
  4. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    Yes, split the signal.
    Or... you could use the second sub for your mains, by running the speaker outs to the subs high pass input, and set your mains to "LARGE".
    But if you want a second sub for LFE, then use the splitter.
  5. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    Also be sure to re-calibrate the system after you add a second subwoofer. Try to set the individual gain(volume pot on the sub)controls so that whenever you unplug one unit..you lose the same amount of volume as when you unplug the other unit. I'd also put the second near the first...assuming the first is optimally located of course.
    TV
  6. Mark Rich
    Mark Rich Second Unit
    Oct 24, 2001
    457
    A somewhat better option IMO is to purchase a sub control unit such as paradign X-30. This will have two sub outs and offer more control of them. It alsogives you more flixibility as to crossover etc.. Cheap and very good.
  7. Howard_S
    Howard_S Supporting Actor
    Nov 1, 2001
    548
    So can you guys rate the best way in order? Is this right?
    1) sub control unit
    2) One to mains, one to output
    3) splitter
  8. Sean Conklin
    Oct 30, 2000
    1,720
    I like option 1, as long as there is LFE bypass or will send a proper LFE to at least 1 sub.
    Then I like option 3, the splitter. Super LFE performance with multiple subs without any extra strain on the receiver.
    Option 2 last, I dont like to run my speaker outs to the sub and then to the mains, a lot of people do it, but I prefer the mains to be set to small and run unburdened by passing through the subs crossover, plus going this route puts a little more strain on your receivers amp.
  9. Howard_S
    Nov 1, 2001
    548
    Can anyone explain LFE a bit more?
  10. Tom Vodhanel
    Sep 4, 1998
    2,215
    8
    LFE is a specific channel. The *1* in 5.1 DVDs for example.
    low frequency effects.
    bandwidth of 3-120hz I think.
    This channel is usually best reproduced by a quality seperate subwoofer in a HT.
    TV
  11. Sean Conklin
    Oct 30, 2000
    1,720
    LFE (Low Frequency Effects)
    DD or dts 5.1 includes 6 discreet channels of audio, the .1 is a dedicated channel containing only discreet Low frequecy information reserved solely for a subwoofer or other capable low frequency reproduction devices.
    LFE is bass information below 150 Hz.
    *EDIT* Tom beat me to it, he may right about the LFE being 120 hz and lower.
  12. Guy Kuo
    Guy Kuo Supporting Actor
    Mar 6, 1999
    581
    Just don't confuse LFE as something which carries all the low bass. The main 5 channels can all carry low bass information. The LFE channel is an optional channel used only to carry low bass effects. It is important to reproduce the low bass content of the main channels as well.
  13. Howard_S
    Nov 1, 2001
    548
    So if I do want to get another sub to complement my other one. Is it best to have the two subs share work or is it best to have one do the LFE. Is it best to have two identical sub or can you have two that are different?
    Thanks for the LFE explanation. I noticed that the LFE icon on my receiver blinks from time to time and so I was wondering what it was.
  14. John H
    John H Second Unit
    Nov 27, 1998
    472
  15. Sean Conklin
    Oct 30, 2000
    1,720
    I think it would be best for you to experiment with dual LFE (splitter).
    In most cases it is best to either stack or put both subs as close together as possible to avoid bass wave cancellation.
    But with some experimenting you might find 1 sounds good up front and 1 in the back. It just depends on your room.
    Maybe Tom or Guy will chime in here and give the lowdown on room modes and it's effect on subwoofer placement.
    And maybe you can post your room dimensions and explain your room layout, i.e. openings, doorways, carpet, etc.
  16. NathanP
    NathanP Supporting Actor
    Aug 13, 2001
    841
    I'd do option 3, for the least complications..
    What you could do though, is make your subs passive and hook them up to a stereo amp and go from the outputs of your amp to your LFE.
    This would be good for say, if you wanted more power..
    I have a 300X2 PA amp and would rather have a 2 300 watt subs then 2, 120 watt subs.
