Can I get VGA output from PS2 ?
Discussion in 'Archived Threads 2001-2004' started by Michael Geiger, Mar 25, 2002.
  1. Michael Geiger
    Aug 25, 2000
    31
    Is there a way to convert ps2 video into VGA for use with a computer monitor ?
  2. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    Yup, but it's all down to how much you want to spend. There's a variety of cheap 'line doublers' by the likes of Redant - usually around $50, and the quality of the output is average to very poor depending on how picky you are. It's not good enough for me, put it that way.
    For more money, the current contender is the Viewsonic VB50HRTV tuner - it allows RGB, composite & RF inputs, all of which it tunnels to any VGA monitor. Supposedly very good at upscaling to resolutions of 1024*768. There's a big thread about them on avsforum. I'm looking into buying one of these myself.
    There's a number of boxes that are much more expensive than that, but I doubt they're of interest.
    The DC's direct VGA output rules the roost - the output from the 'cheap' line doublers doesn't come close.
  3. Shayne Lebrun
    Shayne Lebrun Screenwriter
    Jun 17, 1999
    1,086
    A little bit of background; the PS2 is designed to output to a television, but if you really really want to, you can mangle the signal and send it to a VGA monitor.
    The DreamCast and the X-box are designed to output to a VGA monitor, but if you really really want to, you can mangle the signal and send it to a TV.
  4. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
  5. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    Stefan's point is that the DC internally outputs VGA resolution - the mangling is dropping it down to a signal suitable for TVs. DC + VGA Box is very very good. PS2 + VGA Box is very very poor.
  6. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    If you are so inclined, I believe that you can do this through Linux development kit.
  7. Brad Grenz
    Brad Grenz Second Unit
    Mar 14, 1999
    295
    But PS2 linux is the only thing that would output a VGA signal. Are there actually no fooling Xbox VGA solutions out there? Ones that'll actually give you the native progressive signal? Or are those going to be line doublers too?
  8. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    The ones I've seen, Brad, are all linedoublers. If it's got Redant on the box, ignore it.
  9. Leo
    Leo Second Unit
    Apr 4, 1999
    292
    This just in: Tekken 4 (which was just recently released in Japan) supports VGA using the VGA cable (must use a monitor that syncs on Green) from the Linux Kit.
    Leo
  10. Demetri K
    Demetri K Stunt Coordinator
    Dec 29, 2001
    133
    The only once I have tested that is really good is at ncsx.com. It acctually does a very good job. Only thing is it is expensive. I think around 250 dollars.
  11. BrianB
    BrianB Producer
    Apr 29, 2000
    5,205
    That would be the X-RGB2. An incredibly powerful converter. And it's got the price tag to boot unfortunately.
  12. Patrick_L
    Patrick_L Second Unit
    Oct 18, 1999
    271
    so basically any vga box for ps2 will make games look WORSE than connecting directly to a telivision? reason i ask i because i have an extra 17inch monitor and would like to free up my one and only telivision since i've been hogging it playing SOCOM.
  13. Rob Lutter
    Rob Lutter Producer
    Nov 3, 2000
    4,523
    I recently got the Viewsonic VB50HRTV for $50 on eBAY.
    It works GREAT... I am using my monitor for my television in my dorm room w/ GameCube/XBOX and I am very happy with the results [​IMG]
  14. Patrick_L
    Oct 18, 1999
    271
    wow smokin' deal Rob! i should check there hehe
