Drew Dockery
- Mar 18, 1999
My old receiver is a JVC RX-715VTN. It's just an old Pro Logic receiver, but if possible I'd still like to bring it back to life. I loaned it to a friend from work, and if she liked it she was going to use it to replace her faulty receiver. As it turns out, her receiver was fine, but the power was a problem. Her receiver would play for 4-5 minutes, then shut itself off. Mine did the same thing, only now mine doesn't work at all.
My receiver now has 2 settings - off and standby. I can't get it to actually turn on. Having limited electronics knowledge I opened mine up to look around. I found that a fuse was busted, and after striking out at Radio Shack paid over $5 to get one directly from JVC. I replaced the fuse and the results were the same. Even worse, after doing this, it promply blew the new fuse as well, so now I'm back where I started. Does anyone have any ideas as to what I can try?
Thanks for any help.
