Can I CONVERT a 5 V Trigger to a 12 V trigger?
Discussion in 'AV Receivers' started by NickSP, Jan 12, 2004.
  1. NickSP
    NickSP Supporting Actor
    May 8, 2001
    569
    Is there a way to convert a 5 V trigger to a 12 V trigger? My prepro has three 5 volt trigger outs but they cannot provide enough juice to start the amp which requires a 12 volt trigger. Any suggestions?
  2. Michael Mohrmann
    Michael Mohrmann Screenwriter
    Dec 30, 2001
    1,394
    Nick,
    Which prepro are you using that only outputs 5V triggers?
    Michael
  3. NickSP
    May 8, 2001
    569
    Michael , I am using the Proton AS-2631 processor which has three 5v trigger outs.
  4. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    Which amp are you using? My Rotel 1095 takes a 3V to 30V signal on the 12V trigger input to kick it on.
    Kevin
  5. NickSP
    May 8, 2001
    569
    Kevin, I have an AMC amp that does not have a trigger. I am using a NIles power conditioner with 12V triggers (two) to power on my amps.
  6. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    'Don't know how "DIY" you want to go with this... but a little 12V power supply (wall wart?) with a relay or logic-level FET would do the trick...
    Dave
  7. RolandM
    RolandM Stunt Coordinator
    Jan 21, 2003
    71
    Yeah this doesn't sound hard at all. All you'd need is a 12V supply, some relay(s) that were 5V SPDT or even SPST would work.
    Put the +5V on one end of the coil the negative on the other side; and the 12V connection, one end to the trigger the other to the +12V supply and connect the negative from the supply to the other pole for the trigger. (That should be how the trigger works, right? It should need the + and - connection?).
    You might want to use some fusing in there just in case as well (usually done on the positive wires). As for the relays, I can't be sure of any part numbers to use for 5V coil but I'm sure they are out there. Nothing heavy duty would be req'd either, probably a 5A relay (even less) would do fine.
  8. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    If the pre-pro has a switched power outlet on it you simply plug a 12v power suply into it and connect it to the amp using an appropriate connector on the other end. This is the method alot of us using external amps w/ receivers as pre-pros that don't have trigers at all.
  9. NickSP
    May 8, 2001
    569
    Stephen, as luck would have it, my prepro has two "unswitched" power outlets only [​IMG]
