Can I build a new PC in my NEC 9840?
Discussion in 'Archived Threads 2001-2004' started by Tom Garvey, Nov 22, 2001.
  1. Tom Garvey
    Tom Garvey Stunt Coordinator
    Jan 28, 1999
    122
    I'm ready for something new.. I think?
    Can I rebuild in the NEC box?
    I would like a larger hardrive, faster processor (is this the motherboard?), more memory, CDRW and I guess I will need new graphics & sound cards.. I'd like some USB ports too as I have none..
    It doesn't have to be the best.. just considerably better than 233MHz/MMX/64MB/6GB I have now..
    I use the computer for surfing, business (Quickbooks), word-processing and that's about it.
    I'm guessing I will need a new operating system right?
    Can you guys help me get started? Can it be done for ~ $500? Thanks!
  2. CRyan
    CRyan Screenwriter
    Feb 9, 1999
    1,239
    Usually not. Store purchased PC's usually have a proprietary case and power supply. Not too mention you would need a new power supply anyway.
    The good news is you can probably build a new PC for under $500 with a new case PSU. Check out Newegg.com for prices. I know you can build a 900mhz Athlon with case, burner, etc. for under $500.
    C. Ryan
  3. Tom Garvey
    Jan 28, 1999
    122
    Thanks C. Ryan
    Okay.. I went to newegg and not knowing a whole lot about this I attempted to put something together..
    I hope I can post it here:
    Does this all work together? Do I need anything else? Does anything suck?
    Sorry .. didn't work
