Can Harman Kardon PA2000 amps handle 4 ohm speakers?
Discussion in 'Archived Threads 2001-2004' started by Mark Russ, Jan 26, 2003.
  1. Mark Russ
    Mark Russ Second Unit
    Jun 23, 2002
    341
    I've already got the amps, and I'm planning on getting a pair of Polk LSi25s for mains (set to large), LSi center, 2 different pairs of Lsi f/xs for 7.1 movies (1 pair will be side wall surrounds in dipole mode, other pair will be rear wall center surrounds in bipole mode), and for 5.1 SACD/DVD audio music sources a pair of LSi9s mounted on stands with tweeters at ear level angled in towards listening position in the rear corners. Also dual seperate subs for movies only, most likely will be SVSs ( LSi25s own self powerd built in subs will handle duties when listening to music).
    Amplification for the Polks will be provided by each and every single solitary speaker in the system being passively biamped (by simply removing the jumper straps between the 2 sets of 5 way binding posts on each speaker and wiring each of them to a set of power amp speaker wire binding posts) with a total of 7 Harman Kardon PA2000 power amps, which is rated at 100 watts per channel of pure Harman power at 8 ohms (not sure what it is at 4 ohms though). Note that the rear wall pair of LSi f/x and the rear corner pair of Lsi9s will share the same power amps by having a speaker selector such as those available from Niles Audio switching them back and forth as duties require for either music or movies. In effect, each speaker in the set will have it's own dedicated, bridged HK PA2000 power amp of 200 watts (at 8 ohms) power driving it. Also, a dedicated, seperate pre/pro (which is still undecided at this time). Source will most likely be a Pioneer Elite 45 combination DVD audio/video and SACD player.
    On the HK website, it says absolutely nothing about the 2000s in a 4 ohm load, however, under FAQ, it does state that a 8000 receiver (among other HK receivers) can handle most 4 ohm loads. As I stated earlier in this post, I've already got the amps, and if they won't be able to handle the Polk LSis, then I'll have to choose a different set of speakers, simple as that.
    Opinions, comments, and suggestions welcomed, and thanks in advance.
  2. Greg Kolinski
    Greg Kolinski Second Unit
    Oct 13, 2002
    331
    Since their site says their recievers can handle 4 ohm loads,I would hope their amps do.Especially since I plan on getting one for my 520[​IMG]
  3. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Why don't you cut down on the number of amps by getting HK PA4000's which are exactly equal to 2 HK PA2000. Did you consider Outlaw's new monoblocks?
