Can flipping a shadow mask tube cause damage?
Discussion in 'Archived Threads 2001-2004' started by BryanEB, Nov 6, 2002.
  1. BryanEB
    BryanEB Agent
    Jan 14, 2002
    28
    I just found this thread, in which a guy claims that rotating a shadow mask tube 90 or 180 degrees can cause serious damage.
    Anyone know if there's any truth to this? I just had my TV delivered and they flipped it 90 degrees to take it out of the box. I haven't used it yet, as I have to take the doors off my entertainment center so it'll fit.
    Bryan
  2. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    So long as it is treated gently there should be no problem.
    Shadow mask deformation shows up as: After degaussing, when playing a solid red frame, such as on AVIA or Video Essentials test disk, the screen shows splotches of other colors, same for a solid green frame, etc. For different colored frames, the off color splotches will be the same shape and size and position but in different colors.
    Video hints:
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Quite seriously, I would have requested that the delivery people tear down the box around the unit. I would forbid them to do anything like that to an RPTV of mine.
  4. Aaron Cohen
    Aaron Cohen Second Unit
    Jul 25, 2002
    468
    On my tv, splotches show up when it is on a red frame. The tv was rotated by the people that delivered it. It is a KV-34XBR800, what should be done? I called service people out to look at it but they could not locate me even though I was giving them perfect instructions over the phone AND were given a speeding ticket at one point by the police. They also never stopped cussing!
    I will either not be calling them again (it was through Circuit City with my warranty) or will call again and ask for a different person to come out!
    But in the meantime, any tips for what I should be doing?
  5. SteveMo
    SteveMo Stunt Coordinator
    Jun 19, 2002
    116
    I wouldn't worry. It's better to deal with them in person I think. Mabie they could they give you a ride to your home while you give them directions inside their automobile. Some people try the tv before they accept a delevery but I have never tried it. You should be alright with CC.
  6. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    Jack is quite right. The way to do it is to cut around the bottom of the box and lift the box off the TV. Turning an RPTV on its side is just asking for trouble.
    Jan
  7. BryanEB
    BryanEB Agent
    Jan 14, 2002
    28
    Just to be clear, I don't have an RPTV. It's a direct view (JVC AV-36P903), if that changes the answer at all.
    Bryan
