Can anyone recommend a great TV under $700-800?
Discussion in 'Displays' started by Lee Scoggins, Aug 6, 2005.
  1. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
    Thanks for your help. Looking for a tube-based TV for family room.
    Ideally want hidef capability and screen size of 32-36 and that circuit that keeps volume at same level during commercials...
    [​IMG]
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    I don't think you can buy an HDTV for that price.
  3. Kirk Patrick
    Kirk Patrick Stunt Coordinator
    Feb 25, 2002
    106
    you can pick up a nice 30" toshiba hdtv for less than 700
    if you go refurb, which i would advise in this category of tv as they are very reliable in general, you can spend less for a 30 or maybe get a 34
    or get a 26 lcd flat panel
    lots of choices are out there under 700
  4. Arthur S
    Arthur S Cinematographer
    Jul 2, 1999
    2,568
    Magnavox (and possibly Philips) are the only brands I know of that have the volume control circuit for commercials. Look into Phillips to see if they have it.
  5. John S
    John S Producer
    Nov 4, 2003
    5,460
    Not sure about the volume thing either. But, walmart of all places has some Sanyo HD sets, that get good reviews.
  6. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    Sony has SteadySound volume control also.
  7. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    Any other suggestions? Thanks.
  8. Charlie Campisi
    Charlie Campisi Screenwriter
    Aug 20, 2004
    1,620
    43
    I can't personally recommend it, but some people on the forum have purchased from www.outlet.philips.com. They sell their refurbished tvs direct. You can get a 30" HD ready set for $359 shipped. There are a number of models to choose from and I didn't look at them all, but the $359 model has the volume control you mentioned. If you go this route, post your experiences. It would be a reasonable way to get an HD set for a secondary location like my BR.
  9. John S
    John S Producer
    Nov 4, 2003
    5,460
    Electronics Alley also sells Phillips refurbs.
