Can anyone please tell me the difference between the Toshiba-36hf73 and the 36hfX73??
Discussion in 'Displays' started by Jason Ed, Jan 2, 2004.
  1. Jason Ed
    Jason Ed Auditioning
    Dec 31, 2003
    2
    Hi people, this is my first post here. Ive learned alot just reading. so thanx in advance.
    Im buying one of these 2 TV's this week and i cant seem to find the difference. one is for sale at best buy, the other conn's. Same price, only thing i see different is the front button display is on the outside on the36hf73, while the 36hfx73 has a little click case covering them. Ive looked everywhere on here and on the internet and cant figure it out, please help! thanks.
  2. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    Jason, the difference between the sets is that the "X" stands for Toshiba's "Cinema Series" The Cinema Series usually have better sound systems in them & a few more options than the Regular Series does. By just doing a quick check the 36HF"X"73 has a built in Sub-Woofer the 36HF73 doesn't. You can check out ALL the specs on each model at www.toshiba.com Look under Cinema Series for the "HFX" model & under Color Televisions for the "HF" model.
  3. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    36 X
    36" FST PURE® Flat Picture Tube
    CrystalScan HDSC™
    720p Input Capability
    Zoom Mode
    16:9 Mode (1080i Vertical Compression)
    Invar Shadow Mask
    3D Y/C (4 MB, 10 Bit) Digital Comb Filter with Vertical Contour Correction
    DFine™ Advanced High Speed Velocity Scan Modulation
    Movie and Sports Modes
    Dynamic Quadruple Focus
    Color Temperature Control (Warm/Medium/Cool)
    TruView™
    CableClear™ DNR+
    Cinema Mode (3:2 Pulldown Switch)
    Megaband™ Wide Band Video Amplifier
    MTS Stereo/SAP with dbx®
    Double Baffle Speaker System
    SRS® WOW
    Sub Bass System (SBS)
    StableSound®
    33 W Audio (Total)
    HD Window™ Multi-Scan POP
    Tri-Lingual Icon On-Screen Display
    Closed Captioning on Mute
    V-Chip
    Off/Sleep Timer
    Channel Return
    Power Return
    Noise Muting
    Favorite Channel
    Channel Lock
    Channel Labeling
    Video Labeling
    Video Lock
    Direct Video Input Selection
    Individual A/V Settings by Input Type
    Speed Tuning
    GameTimer™
    On Timer
    PIP Sound
    Speed Surf
    2-Level Mute
    Front Panel Lock-Out
    QuickConnect™ Guide
    SurfLock™
    RF Input (2)
    Front Panel A/V/S Input
    Dual ColorStream® HD Component Video Inputs
    Rear A/V/S Inputs (2)
    DVI/HDTV Input
    A/V Output (Fixed and Variable Audio)
    Variable Audio Output
    Center Channel Audio Input
    Illuminated A/V Universal Remote Control (6 item)
    Unit: 38 3/16" x 29 9/16" X 24 1/4" (W,H,D)
    154 Lbs
    36 hf
    CrystalScan HDSC™
    Zoom Mode
    Invar Shadow Mask
    TruView™
    CableClear™DNR+
    SRS® WOW
    StableSound®
    20 W Audio (Total)
    HD Window Multi-Scan POP
    V-Chip
    Off/Sleep Timer
    Channel Return
    Power Return
    Noise Muting
    Favorite Channel
    Channel Lock
    Channel Labeling
    Video Labeling
    Video Lock
    Speed Tuning
    Game Timer™
    On Timer
    PIP Sound
    Speed Surf
    2-Level Mute
    QuickConnect™ Guide
    SurfLock™
    RF Input (2)
    DVI/HDTV Input
    Illuminated Universal Remote Control (4 item)
    Unit: 38 3/16" x 29 9/16" x 24 1/4" (W,H,D)
    154Lbs
    Looks to be a better remote!
    Brent
  4. Jason Ed
    Dec 31, 2003
    2
    WOW, thanx alot guys! much appreciated..
    I guess I will go with the X!
    Now I just have to post about which DVD player to match my TV!! but thats for a different thread[​IMG]
