Can any UK readers recommend speakers?
Discussion in 'Archived Threads 2001-2004' started by DannyS, Aug 13, 2001.
  1. DannyS
    DannyS Second Unit
    Jul 9, 2001
    328
    I'm looking for a 6.1/7.1 set up for around £500 - £600
    I have a 5 metre square room.
    They'll be mostly used for movies and a little music.
    any suggesstions?
    Panasonic TX-21M2T TV
    Sony DVP 536
    Old Panasonic Stereo! :)
  2. Iain Lambert
    Iain Lambert Screenwriter
    Jun 7, 1999
    1,345
    As a start, I'd go straight to your nearest Richer Sounds and ask for some advice. They have always been helpful to me, have some absolute bargains on at the moment, and you could book a demo room and actually hear some stuff. Personally, I'm a fan of anything Celestion - they do a nice bundle of F2 mains with smaller rears and a centre quite reasonably, although you might want to see if they would let you upgrade the F2s to F3s; on your budget you'd afford it. Mine match reasonably with my Paradigm sub if you have room for one, but go down far enough its not the end of the world in a small room.
    edit - goodness knows where I got the idea of a small room from. Add a Paradigm PDR-1000 to your list now.
    "I'm a reasonable man, get off my case" - Thom Yorke
    [Edited last by Iain Lambert on August 13, 2001 at 11:29 AM]
  3. Richard Cooper
    Richard Cooper Stunt Coordinator
    Mar 21, 2001
    132
    Hi Danny,
    For that budget, I'm thinking that you might be better off buying a better quality 5.1 set of speakers, with the thoughts to maybe adding a further 1 2 matching speakers at a later date.
    The nearest specialist shop I know of is Action Gate Audio in Wrexham (01978) 364500. I've never dealt with them, so I don't know what they're like, but I'm sure they could help. Otherwise, yes Richer Sounds might be able to sort you out with something.
    Adding a bit to what Iain said; you MUST audition any speakers you are interested in, if possible in teh room you're going to install them in.
    Richard
