Can an EQ or BFD help my SVS standing wave disaster!?
Discussion in 'Archived Threads 2001-2004' started by Troy_K, Feb 21, 2002.
  1. Troy_K
    Troy_K Stunt Coordinator
    Jan 20, 2002
    87
    I can't figure out how to put a graph in here, so please bear with my figures. I would appreciate help with a solution to my bass woes. I have a 20-39CS+, and have tried 2 different corner placement options. These measurements are with one port plugged (doesn't really affect the overall FR curve with it out).
    Corrected SPL data:
    Hz left right (corner)
    16 73.5 74
    20 69.5 69.5
    25 68 67.5
    30 72 73
    35 72.5 74
    40 66 60.5*
    45 62 65
    50 60.5* 69.5
    55 74 76.5
    60 80.5* 80*
    65 77.5 79.5
    70 72 69
    75 71 61.5
    80 61.5 70.5
    85 70 73
    90 68.5 71.5
    95 70.5 70
    100 70 71.5
    Now the questions:
    Will I be able to successfully EQ those deep peaks and valleys that I have, or is my room just too strong of a barrier to smooth FR? Should I get the ART EQ or BFD? Or should I simply build a new house (:
    Which placement is better? Left or Right corner? I've tried moving my seating position back, but can't go any further. How screwed am I here?
    Troy
  2. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    Hi Troy,
    I'm sure one of the guys who are really knowledgeable about this topic will jump in and help you soon. I just wanted to offer some encouragement by telling you I've read some BFD posts on this forum where the poster was able to smooth 30-Db peaks! So don't despair, it may be possible to smooth our your FR.
    Good luck!
