Can a NuVo Concerto control a PC???
Discussion in 'Computers' started by dannyBie, Feb 4, 2006.
  1. dannyBie
    dannyBie Auditioning
    Feb 3, 2006
    Hi there,
    I'm a newby here on HTF. I hope I have posted this in the right section of the forum...here goes!
    I have a NuVo Concerto system hooked up with four zones and only one media source - a PC running Windows XP Pro (not MCE).
    Currently, the PC can be controlled by a NEVO SL remote, however I would like to be able to control the PC via the Concerto keypads to give the following functionality:
    A) Select from audio files on the PC (Album/track/random/repeat functions - maybe playlist???)
    B) Select from internet radio stations (perhaps ones I preset so you can scroll through them)
    C) Have multiple sound cards to act as multiple sources so that I can have different media playing in different rooms
    Can this be achieved and if so, how?? What software/hardware would I need?
    Thank you,
    Danny in Sydney, Australia
  2. Vivek_IVB
    Vivek_IVB Stunt Coordinator
    Dec 26, 2005
    90
    Hmmm. The Concerto has an RS232 interface, right? If so, I think there must be a way to use my HA/HT package, CQC [www.charmedquark.com] to do this; we need to figure out how to use the concerto keypads as an input device; that could be the sticky wicket. You may want to post a question on the forums there about this as the tech guys there may have a path available.
    Everything else is doable. I don't think there's a current CQC driver for the Concerto, but that's overcome-able.
    In that case, all you'd need is CQC, which is $200 base [$300 for the full suite if you go whole hog, but you only need the base for your current fxnlty]
    BTW, you don't need multiple sound cards. One delta 410 (i just got one for $60 off eBay) will do the trick. It can handle 4 concurrent audio streams, and you can use 4 instances of ZoomPlayer standard [free] to drive each zone. CQC in turn can drive what gets rendered on each zone.
