Mike Schmitz
- Jun 10, 2000
My computer kept crashing. After replacing the motherboard, it crashed again. Someone told me that if there's a really bad electrical problem, bad electricity can shoot right through a cheap Uninterupted Power Supply. They told me I should get an electrical tester from Home Depot.
The test tool is from "Commercial Electric" and cost about $8. It has three lights, one red and two yellow. When I plug it into any outlet in the basement, only the middle yellow light comes on, which means "Open Ground." When I plug it in anywhere else in the house, the two yellow lights come on, which means everything's fine.
When I push the reset button on the tester upstairs, nothing happens. Both yellow lights stay on. But when I push it in the basement outlets, the red light also comes on, which indicates a "Hot/Neutral reverse." When I let go of the reset button, the red light goes off, and only the yellow middle light is on.
So I have either an open ground or a hot/neutral reverse in the basement circuit. I probably need to get an electrician out to the house, but I'm not sure how much the repairs will cost. The previous owner from 20 years ago or so seems to have (1) done some wiring work on his own and (2) was aparently an idiot.
While I'm saving up enough money to get the repairs done, my computer is gathering dust. I don't want to move the computer hutch back upstairs, and I'm not sure I could reassemble it if I took it apart. Also, I'm pretty set on keeping the PC in the basement, since there's Comcast cables down there, and I eventually want a cable modem.
So, finally, here's my question: Will a very high end UPS protect my computer from bad electricity? Or should I not risk my computer crashing again? (I managed to repair it myself, this time)
