Very solid amp section (will drive a 4 ohm load), a bit sparse on features, fixed xover at 80hz, 6.1 receiver, especially good with music (compares well with integrated amps and is a notch better with music than the usual suspects in its price range).
If you don't need bells and whistles and your speakers can properly mate with an 80hz xover, then this is a receiver that merits serious consideration.
If you want auto-eq, 7.1, flexible bass management settings, then a Yamaha, Onkyo, Denon or Pioneer is probably a better choice.
