Calling bassheads - setting crossover on sub (1 Viewer)
Jason GT
Hi all,
First off, this is not meant to be the typical crossover setting type question. :)
Take a look at this article.
On the lower left corner of first graph are freq response curves for a subwoofer, measured at different sub-level crossovers. As the crossover is turned down, the freq response flattens.
My question is, has anyone deliberately turned down their sub crossovers to flatten sub frequency response? Any insight/tips/tricks on doing this?
FWIW I'm running an HK 320, PSB Alpha Bs (good down to about 55-60 hz) and a Paradigm Pw-2200.
Steve_Ma
The optimal crossover point is going to be largely dependant upon the room as well as the sub and adjoining equipment.
I have adjusted my sub's crossover in the past to experiment with the frequency response my room/equipment was giving my at different crossover points. My AVR has a fixed crossover of 100hz and I wanted to see if I could get a better response by lowering the cross and getting more from my mains.
So of course I had to dump the line level connection and use the speaker level connections for the sub/mains. I changed the speaker settings in the AVR. I then used a test disk to play different test tones and I measured and charted my freq response at various crossover points ad nauseum.
It was a great excersize that taught me alot about my room and my equipment. In the end: My line level connection and fixed 100hz crossover clearly gave me the flattest frequency response.
My Advice: Get a test disk and make sure you chart your results at various points.
Arup
Since I have good bass capable towers attached to a high power amp, I use 60Hz for my sub setting and this gives me seamless blending with the towers.
JohnDG
Yep: I did this with Paradigm Monitor 7's and a PDR-10. In my setup, the 7's are corner loaded (unavoidable), so I got a hump at the crossover. By setting the sub's crossover within 10 Hz of the receiver's crossover, I was able to flatten the curve.
jdg
JimmyK
Jim
My L&R speakers are strong down to 40hz, so I thought that a lower crossover point would benefit my system.
After much measuring and experimenting, I found that my main speakers had a large bump between 80hz-125hz.
The solution was to set my low pass crossover to 80hz, and the highpass to 150hz. Although this looks strange on paper, it actually resulted in a smooth response from 15hz on up through the treble region without having to apply any EQ.
It pays to experiment.
JimmyK
Peteo
