Jeff
- Jun 30, 1997
I auctioned a Slot 1 SECC2 100MHz Bus Speed Pentium 3 chip on Ebay about two weeks ago. This was a CPU I bought brand new OEM around May 2002, which wasn't easy to find, and I used it very often for just over a month with no problems with stability of any kind. The fan/heatsink was a Golden Orb (rated up to 1.13Ghz) and in between I had a properly done layer of Artec Silver III compound. The CPU case & case temp was in the "normal" range.
Anyway, as soon as the auction winner received the item, he emailed me and said that it works fine and then he left me positive feedback. Four days later he emailed me again saying that after about 4 hours of total use the CPU died. I was shocked to say the least, thinking it impossible if I had used the CPU for 4 more hours myself, it would have failed.
First of all, my auction stated "Please do not bid if you are not sure about your motherboards specs or have no experience installing a CPU."
Now this guy seems to have some PC knowledge but some of the things he told me makes me wonder just how much and maybe I'm the one who's not too knowledgable in this area, who knows.
He told me that his motherboard is called an "ATI DUAL SLOT 1". Well correct me if I'm wrong, but I don't think ATI makes motherboards. They list nothing on their site about MB's. He also said the dual slots are set up for Windows 2000 only and not the OS he is using, which is 98SE. Since I know nothing about dual slot mobos, I have no idea if this makes sense or not, but maybe 98SE doesn't support dual processors? He has also stated that his case temp is 50 degress C (123F) at IDLE with his old 450Mhz P3. IMO, and I could be wrong, this temp would go up 3-5 degrees with a 1Ghz chip. And, again, unless I'm mistaken, the actual 1Ghz CPU temp would probably be around 63 to 65C at IDLE. Who knows what it would be under full load. When I was using this CPU my case temp was 30 to 34C and even that was high because I was using an Abit Bx6 board that runs hotter than most mobos. My current mobo is 27C and CPU temp never goes above 46C. So at full load on this guys computer, this chip COULD have been sizzling at a temp possibly as high as 70C.
So, I guess the big question is, can this CPU die at this temperature? I know it's way too high. The failure he describes sounds heat releated since he says after the 3rd boot up it only lasted for 15 minutes and then it died. I once killed a P3 CPU myself for not putting thermal grease on. (I've known better in recent times.) Anyway the CPU lasted about 10 minutes and after a couple reboots that was it, it would not reboot anymore. Sound familiar?
I will say, this guy is very nice and the fact that he reported a 50C IDLE case temp with his old CPU, shows he is honest. He also has never raised the issue of wanting money back as of yet.
Should I atleast offer him to send me the CPU to look at or should I tell him he's SOL? (Not in that way of course).
BTW, the reason I sold the CPU is because I needed a mobo that supported 4X AGP.
Thanks for reading this novel.
Jeff
Jeff
