Scott Aruti
- Mar 6, 2004
My surround system is calibrated through the RECEIVER, for example, each channel is balanced through the receiver's settings, as well as distances, etc....I read my DVD player's manual this morning and there was a chapter dedicated to setting up the surround system through the actual DVD player----in other words, there is a way to calibrate the speaker system in a surround setup on the DVD player's menu, putting in dB levels for each channel, distances, etc....I have left all these at "0" because I thought I was calibrating through the RECEIVER, not the DVD player....does anyone know if you have to set your system up through the DVD player, or BOTH the player and receiver or if everything is fine the way I have it, with all levels at "0" because my receiver already calibrated and set the levels?
Receiver is an Onkyo TX-SR600, player is a Panasonic DVD-RA60.
