Kevin Reckelhoff
- Aug 16, 2001
Just ordered one of the Ideal Lume backlights along with a dimmer kit. Now I'm trying to figure out how to determine which level of filtering to use so that the light output is "no more than 10% of the monitor's peak light output".
The wall behind the set (32" Wega) is off-white, so I expect a filter will be needed. Is there any technique to this that's more effective that visually "guessing"? I have Video Essentials but I don't remember it describing any method for assessing this. Would the Avia disk be a better choice? I'll need to recalibrate the set with the light--should I adjust the light level first and then the set, or the other way around?
Thanks!
Kevin
Thanks!
Kevin
