Calibration problem? :( (1 Viewer)
Paul_S
I have a Yamaha 995 receiver and it doesnt display the db level like other receivers. So basically using my Radio Shack SPL Meter I would use the volume control on my receiver until I get a 0 reading(12o'clock)on my meter at the setting of 75db for my main speakers first. Then I would adjust the other speakers to get a 0 reading and then adjust the sub a little higher than the others. I am using the Avia test disk to do this. I am doing this correctly?
Phil Iturralde
Yes, it sounds correct.
Note that the numbers on the flange behind the Volume Control represents dB, so the 12 o'clock position is -16 dB. When you REF Calibrate, just note the Volume Control Knob location.
In my case, my Yamaha RX-V995 REF Level Volume Knob location = -12 dB (or 1 o'clock position). See my complete REF Level settings using Video Essentials (I have AVIA but use VE for speed and LFE REF Calibration) @ my webpage http://www.geocities.com/p_iturra/VE_995.html
[Edited last by Phil Iturralde on July 17, 2001 at 08:44 AM]
Paul_S
On the analog Radio Shack meter it has the db's set in increments of 10. So if i set it to 70, what range and im getting? Would the 0(12 o'clock) position be at 70 db's or 75 db's? This is the part I am confused about
Bill Kane
When one sets the RS SPL meter to 70, the O at 12o'clock mean 70dB while 75dB is 5 "clicks" or scale marks to the right.
Phil Iturralde
Dial = 70
Speed = SLOW
Weight = C
DIAL Readings
0 (or 12 o'clock high) = 70 dB
+6 (positive side of "0") = 76 dB
. . . so the 'tick' mark between +4 and +6 = 75 dB
NOTE:
1) AVIA recommends using 85 dB (-20 dB below Digital 0)
2) Video Essentials recommends using 75 dB (-30 dB below Digital 0)
3) Yamaha internal test = VE / 75 dB REF Level
Review my http://www.geocities.com/p_iturra/PCI.html
[Edited last by Phil Iturralde on July 17, 2001 at 12:23 PM]
DanG
[/quote]
The Radio Shack meter to me is worth its weight in gold.
As much as I like and use the Avia, for me setting channels levels with it is problematic. Since it doesn't have a LFE track like the VE disc it counts on my receiver to redirect the one or all of DD 5 channels to the sub for bass. Unfortunately I have the Denon set to LFE only for the sub and this doesn't work at all well. So I use the VE for channel level setting.
[Edited last by DanG on July 18, 2001 at 12:37 AM]
tgroskop
