Calibration discs (AVIA, VE, etc.): TV and DVD Picture Calibration Question
Discussion in 'DVD' started by Kage, Aug 24, 2003.
  1. Kage
    Kage Stunt Coordinator
    Mar 16, 2003
    127
    Do you guys recommend Avia Guide to Home Theater calibration dvd for a HDTV Direct View TV?
  2. NicholasL
    NicholasL Second Unit
    Apr 3, 2003
    298
    I use it, and I would.
  3. David Susilo
    David Susilo Screenwriter
    May 8, 1999
    1,197
    even the worst calibration DVD will make any consumer-grade TV look better than not being calibrated at all.
  4. Jigesh Patel
    Jigesh Patel Stunt Coordinator
    Jun 16, 2003
    137
    I used Video Essentials (VE) and I highly recommend TV calibration. It does make pleasant difference. Earlier I was using Panasonic RP82 DVD player and probably got used to its deafult settings. When I bought Pioneer 563A, I did not like its default video settings. I had never calibrated my CRT-based direct view interlaced TV. After calibrating it with VE, I now notice what I had been missing! Compared to audio calibration with sound pressure level meter, video calibration is sometimes more subjective for certain test/calibration signals [especially so since most non-professional calibrations (including mine) for direct-view TV are done without any video measurement instruments]. Despite that, TV calibration is worth the trouble.
    Jigesh
  5. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    YES. a THOUSAND times yes. TOTALLY worth it for both audio and video! I use Avia, not experienced with VE, both should suffice fine i'm sure.
