Calibrating multiple inputs ? (1 Viewer)
Dave Pobuda
I have a Mits WT-46809 which I have calibrated the DVD Input using Avia. My question is how do I get the DTV Input calibrated ? Mits does not use a numerical value to show you your color/tint/brightness/contrast settings. So I've tried to set the slider's in the same position. I know this is not accurate and was wondering if there is another way of doing this? My SO will not even entertain the thought of a ISF Calibration(although I have not given up on that one just yet). Any help will be appreciated.
TIA ;)
Dave
Michael TLV
THX Video Instructor/Calibrator
Calgary, Alberta
Michael Chen
Greetings
In terms of grayscale calibration, the set can handle two specific grayscales ... one for low and one for high ... and medium is sort of an average of the two.
Best bet is still to calibrate to DVD and use that as the starting point for all other signal types. Everything else is far less consistent than DVD.
Regards
AlohaTiger
