Calibrating Audio
Discussion in 'Archived Threads 2001-2004' started by Steve Herman, Oct 23, 2001.
  1. Steve Herman
    Steve Herman Auditioning
    Apr 22, 1999
    7
    I have a Denon 3801 with a JBL NSP1 speaker package, and was wondering on the correct way to set the proper audio levels for the speaker channels. I have the VE disc, but am unsure the volume to set my receiver at when setting the levels. Any help is greatly appreciated!
  2. Vin
    Vin Supporting Actor
    Oct 23, 2000
    546
    Read this .
    Good luck!
  3. Tom Morgan
    Tom Morgan Stunt Coordinator
    Aug 1, 1999
    119
  4. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    If the volume control is relative, ie it lists -XXdB to +XX dB then you want to set the volume to 0.0dB.
    If it is not listed as relative dB, it might list a particular setting as REF. Other than that, you have to ask Denon.
    Double check the VE disc, I don't recall off the top of my head whether the tones are at -30dBFS or -20dBFS. If it's -30dB, you then calibrate to 75dB for all speakers and sub. If it's -20dB you then calibrate to 85dB for all speakers and sub.
    If you're using the Radio Shack SPL meter, it's a bit off on the low end, and you should calibrate 2-3dB under the other speakers for true level response.
    Hope this helped.
