Anthony Stephan
- Mar 6, 2000
In regards to hooking up my VGA/Component converter from an RCA DTC-100 to the HD Monitor.
Which would be better, or would there be a difference if...
I hooked up a 10' VGA cable to the receiver and a short component cable to the TV.
Or should I just use the short VGA cable and use a long component cable.
It would be easier for me to run the long VGA because I am out of power outlets behind the rack! If I run the long VGA, I can plug it in behind the TV.
Would it make a difference?
