Cables for Paradigm Active 40's ???
Discussion in 'Archived Threads 2001-2004' started by John Cain, Oct 21, 2001.
  1. John Cain
    John Cain Second Unit
    Nov 19, 2000
    359
    What cables do folks here use or recommend for Paradigm Active 40 Speakers??? Also do you use RCA or XLR Cables??
    I want a good cable but do not want to have to re-finance the house to buy them [​IMG]
    I will probably have a pretty long run of cable to the farthest speaker, it could be up to 33 feet.
    Thanks for all replies,
    -- John
  2. Vince Chan
    Vince Chan Stunt Coordinator
    Aug 22, 2001
    110
    At the very least, twin runs of generic 12ga speaker wire.
    Better would be something like Tara Labs Prism Biwire cable.
    Best would be...??
    -Vince
    http://www.arcticcircle.ca/about.htm
  3. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    Um... it's an active speaker, I think he needs interconnect cables, not speaker cables.
  4. John Cain
    Nov 19, 2000
    359
    Correct...
  5. Charles J P
    Charles J P Cinematographer
    Aug 19, 2000
    2,049
    3
    Omaha, NE
    CJ Paul
  6. Ron Alcasid
    Ron Alcasid Stunt Coordinator
    Apr 11, 2000
    168
    I'm just using the cables that came with the 40's. They are made by AudioStream. They don't look like anything special but are much better than the freebie stuff you usually get. The cables are double shielded and use an OFHC conductor. The jacket is white so it blends with the walls if they are a lighter color. Each one is about 25 ft. long.
  7. John Cain
    Nov 19, 2000
    359
    Thanks Ron. I didn't know the Actives came with Cables..
    I found out today when my speakers arrived. [​IMG]
    -- John
