Cable TV Signal Booster?
Discussion in 'Archived Threads 2001-2004' started by Tim Jaeger, Jul 20, 2002.
  1. Tim Jaeger
    Tim Jaeger Auditioning
    Jul 20, 2002
    2
    Hi everyone:
    I'm a newbie to this forum, but I'm glad I found it!
    I have Cable TV, and over the years I've split the signal to send it to three different televisions in the house. Just recently, on one of the TVs channels 2 through 6 have become very snowy, ghosting, etc. It's only happening on one of the TVs though, the other two seem to be fine. Can anyone help with my problem, and would a signal booster help? If a booster would help, any suggestions on what kind to get? Thanks a lot!
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    HI Tim. Welcome to HTF! [​IMG]
    I dont think you need a booster. You could have 2 different issues:
    1) Your wires are loose/corroded. Trace your wire into your house. Un-screw every connection and examine the center copper wire. Is it bright/shiny copper or a dull brown? I might be a good idea to cut the ends off a few inches and install new connectors with fresh/clean copper showing. Be sure to tighten all connectors with a wrench, about 1/4 turn. (A loose connector is the number one cause of problems/service calls with the CATV system).
    2) The signal is having problems up-stream. Once you have checked/replaced your connectors and the problem remains, call your CATV company for a service call. They will come out and test the signal strength on several channels and trace the problem. This could be a poor amplifier on a pole near your house, or in my case once, a tree-rodent had been chewing on a jumper wire on top of the pole. This cause noise/snow on some channels, but not on others.
    Hope this helps.
  3. Tim Jaeger
    Jul 20, 2002
    2
    Thanks for the advice, Bob! I'll give it a try.
  4. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    Bob, that's just on one TV, though!
    Yes, make sure that the connectors are all tight, but a cable could have gone bad, too. If you can swap cables and it goes away, the cable is the problem.
    If you have to buy a new cable, get an RG-6, rather than an RG-59. The 6's have a better signal strengh.
    Glenn
  5. Mike Matheson
    Mike Matheson Second Unit
    Jul 15, 2000
    416
    Tim,
    Welcome to HTF.
    I've heard rumors of better quality splitters (from Monster and others)--you might wish to look into this. Perhaps the splitters themselves could also be improved inexpensively.
    Mike
  6. Colin-H
    Colin-H Second Unit
    Jun 25, 2002
    391
    A squirrel might've eaten your cable up at the pole. It happened to me.
