Hi all,
I just moved into a new house and discovered how wacky the cable wiring really is. I want to redistribute the cable signal, but had a few questions about the best way to approach it so that the signal doesn't degrade too much.
Currently, the outside cable goes into a 3-way splitter (also outside). The outputs are marked "-7dB", "-7dB", and "-3.5dB".
Do the numbers indicate the relative strength of each output signal?
Is the signal from the "-3.5dB" output twice as strong as the "-7dB" outputs?
Realistically, how many times could I split each of the outputs without degrading the signal too much and introducing a lot of interference?
What kind of splitters should I get to distribute the signal (i.e. is there something special I should look for)?
Generally speaking, is it better to use one 3-Way splitter rather than two 2-way splitters, or does it even make a difference?
Thanks for your help and insight.
-Jason
-Jason
