Cable splitters. Any advantage
Discussion in 'Archived Threads 2001-2004' started by Kevin. W, Jan 15, 2003.
  1. Kevin. W
    Kevin. W Screenwriter
    Oct 27, 1999
    1,534
    I just got Digital cable installed. From the source I'm splitting it to my Computer, TV and RPTV. Is their a difference between a 4way splitter thats rated 5/1000 and 5/2.4GHZ as far as picture quality is concerned?
    Kevin
  2. Adil M
    Adil M Supporting Actor
    Nov 21, 2001
    922
    Quality.... maybe.
    I know w/ Digital Cable you are supposed to go w/ the wider bandwidth splitter.
  3. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    Kevin, if you stop by your local cable TV office, they should supply you with free cable splitters. These are usually the good heavy duty kind too.
    Also, you can have your cable company guy come out and check the signal strength. They can do certain tweaks to bump up the signal strength, and while they are there, they can supply you with better splitters, better cable, etc. Again, all of this is usually free if you tell them that your signal strengh may need help.
  4. Kevin. W
    Oct 27, 1999
    1,534
    Thanks for the info.
    Kevin
  5. NickT
    NickT Stunt Coordinator
    Nov 20, 2001
    104
    10
    Nick
    There's no effect on picture quality between the two. The first one is a 5MHz to 1000MHz (Megahertz) splitter and is used for cable. The second is 5MHz to 2.4GHz (gigahertz) and is used for satellite.It's simply a rating of what frequencies the splitter will pass through.
  6. Adil M
    Nov 21, 2001
    922
    You may miss out on some channels if you use the lower bandwidth splitter on digital cable or satellite.
