cable signal amplifiers/boosters
Discussion in 'Archived Threads 2001-2004' started by ThomasL, Apr 7, 2002.
  1. ThomasL
    ThomasL Supporting Actor
    Mar 13, 2001
    963
    This was sort of discussed piggyback on a separate thread but I'd like to ask everyone if you use a cable signal booster and if so, what brand/model do you use? And how well does it work? Did you do any before and after tests to see what the difference was?
    thanks much,
    --tom
  2. Rick_Brown
    Rick_Brown Second Unit
    Oct 25, 2001
    449
    I use a new Radio Shack amplifier. I don't recall the model number, but the packaging says that it is a new generation which can pass signals in both directions, making it suitable for cable modems and digital cable TV. I use it on my digital cable line. Without it, I get snowy analog channels and pixelating digital channels. With it, problem solved. I know may folks will say that it also amplifies noise, and others will say to call in your cable company if you have poor reception, but it's easy, cheap and works great!
  3. Robert Cranwell
    Robert Cranwell Stunt Coordinator
    Jan 1, 2002
    51
    Try these out. Aska, Lindsay,Toner,Viewsonics,and Qintar are all favortes of the CATV Industry.
    Rob
  4. ThomasL
    Mar 13, 2001
    963
    Robert, do you have any specific models you can recommend? What I'd like is something to boost the signal 10db and split the signal 4 ways - i.e. replace my current Radio Shack splitter with one splitter/amplifier device. I think we talked a little on the other thread. I'm the guy who has about a 90-100 foot run from the street and then the signal is split 4 ways and there are 4 runs anywhere from 35-55 in length (using RG-6 and RG-59 cable) to 4 tvs in the house. I don't have a cable modem yet.
    thanks,
    --tom
  5. Robert Cranwell
    Jan 1, 2002
    51
    ThomasL, This should be what you want www.viewsonic.com
    model # vsa-604L Good amp with reverse path and 4-output splitter built-in. Hope this helps
    Rob
