cable question
Aris A
Are 8 AWG wires good for amp/speaker use? No problem with signal transfer?
ChrisWiggles
Sure. 8awg is pretty fat though, you may run into difficulty connecting them to regular sized connectors.
homthtr
Steve
You could run all the power requirements for 2 houses on 8 guage wire!. 16 is the normal minimual 14 is kinda the above any system requirements and 12 is even way overkill for just about any system. Even 14 is isn't compatable with lots of inwall volume controls, etc. Most of them will only take up to a 16 guage. Stick with a high strand count wire. We normally wire all houses with 16 guage 65 strand wire. We only Use 14 when when requested, or for higher end systems.
gullfo
