Cable modem surge protection
Discussion in 'Archived Threads 2001-2004' started by Mike OConnell, Feb 4, 2002.
  1. Mike OConnell
    Mike OConnell Second Unit
    Jun 14, 1999
    489
    Overland Park KS
    Mike
    I could not find another appropriate place to post this....
    I have a cable modem (Time Warner Cable in Overland Park, KS) and currently have no type of surge protection on the cable line to the computer.
    Should I get this?
    The only surge protector I have found that claims to have the ability to protect cable modems is the APC Pro8TV. My concern is buying a surge protector that slows down my connection and a standard TV surge protector will do this.
    Any suggestion are appreciated.
    Mike
  2. Mike OConnell
    Jun 14, 1999
    489
    Overland Park KS
    Mike
    bump
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    Yes, it would be a good idea to have one
    Unfortunately I have no suggestions [​IMG]
  4. JamesMH
    JamesMH Stunt Coordinator
    Mar 8, 1999
    74
    I use these for my satellite, used to use the same when I had a cable modem.
    Belkin
  5. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
  6. Mike OConnell
    Jun 14, 1999
    489
    Overland Park KS
    Mike
    I was told by a salesman at a computer store that you can't use a "standard" cable TV surge protector because it does not have adequate "bandwidth" for the cable modem application.
    He had no surge protectors in stock that were "rated" for use with cable modems.
    Now, whether he knew what he was talking about I don't know... That is why I asked the question here.
    Mike
  7. Craig F
    Craig F Second Unit
    Jul 5, 2001
    276
    Craig
    I would get one designed for computer networking. Most networks today use Cat5 cabling, but there should be some solutions for the older coax interfaces. Some keywords you might try searching for are "thinnet" and "10 base-2".
  8. Mike OConnell
    Jun 14, 1999
    489
    Overland Park KS
    Mike
    I e-mailed the "help" line this morning at APC with this question:
    "I am interested in a surge protector that can protect against surges on my Cable modem line (coaxial), as well as for my home PC. The Pro8TV seems to be the one I need, but there is a lack of information on whether the bandwidth is high enough to handle my "Roadrunner" (Time-Warner Cable) cable modem service.
    I just need to know - does this surge protector have adequate bandwith to not degrade the speed of my cable modem transmissions?"
    Here is their answer just 6 hours later:
    "Dear Mike O'Connell,
    Thank you for contacting APC on 2/06/02.
    You are correct the PRO8TV will protect against surges on your Coaxial Cable line. This would be an excellent surge device for you.
    This surge protector will not degrade the speed of your modem. The Time-Warner Cable service should suffer no slow down due to the Surge Station. Your bandwidth will be the same through the PRO8TV as what it is coming from your cable.
    I hope that I answered your question for you, Mike. If not, or if you have any further questions, please do not hesitate to contact me. It would be my pleasure to assist you!"
    I love good service!
    Mike
