Cable Management
Discussion in 'Archived Threads 2001-2004' started by Ken Custodio, Mar 6, 2002.
  1. Ken Custodio
    Ken Custodio Second Unit
    Dec 5, 2001
    316
    Anyone have some tips on cable management for the spiders web of cables I have behind my equipment rack. Or know of any handy gadgets to help out?
    Ken
  2. PaulKH
    PaulKH Second Unit
    Oct 3, 2001
    413
    I like using those plastic cable ties (pull tight with a zipper sound). I got all the audio/video connections (*10* including 6 analog, 3 component and 1 digital) between the DVD player and the receiver tied like a 'harness'. I try to get the power cables together too and away from the A/V ones.
  3. Trent C
    Trent C Agent
    Dec 3, 2001
    38
    When I built my furniture I used plain old velcro. Screwed a few pieces to the back. Works wonderful and very inexpensive.
    I also like to keep the wires separate -- speaker, power, audio and video.
    Trent
  4. Michael Lee
    Michael Lee Supporting Actor
    Jan 7, 1998
    652
    I used plastic wire ties and a short length of raceway for my living room setup.
    [​IMG]
    [​IMG]
    Good luck!
  5. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Wow those before/after pics are dramatic!!!!
    I bought a rack that has big huge fat legs with cable management built in. That's a great solution!!!! [​IMG]
  6. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I like to put the receiver/amp on the BOTTOM shelf. This allows the speaker wires (which carry power) to flow out without covering the back of the rest of the equipment.
    I run the power cords to one side of the rack & loosly bundle them with velcro strips.
    The interconnects are all bundled together down the middle with either velcro or split-loom tubing (Radio Shack).
    I would avoid the nylon zip-ties because of Murphys Law of Cable Management:
  7. Philip Hamm
    Jan 23, 1999
    6,873
    2
    Actually I use a little $30 Brother label machine to label my cables. (just some of them) It works great!
  8. Ken Custodio
    Dec 5, 2001
    316
    That "before" picture looks like my setup. Atleast I know it is possible for it to look like a neat and tidy [​IMG]
    Ken
    Btw, thanks for all the tips, that is a good idea to put the receiver on the bottom.
  9. PaulKH
    PaulKH Second Unit
    Oct 3, 2001
    413
    Michael Lee - I like your simple looking rack. Looks sturdy too. What kind is it? Where can I get one?
  10. Michael Lee
    Jan 7, 1998
    652
    Thanks for the compliments!
    Paul-It is a Sanus Euro Rack. It is extremely sturdy and is modular in design. I just added a 5 channel amp on top that weighs about 130 lbs. and it is fine. I will post a pic of it later.
