Cable Management
Discussion in 'Archived Threads 2001-2004' started by John_KC, Feb 22, 2002.
  1. John_KC
    John_KC Auditioning
    Jan 31, 2001
    4
    Hey guys....
    I tried to do a search but did not come up with anything regarding cable management(unless I was searching for the wrong keyword).
    Do you guys know of any good cable management?? The better-half is getting a little touchy about all the spaghetti cable that we have behind the receivers and along the walls.
    Any help would be appreciated.
  2. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    i recommend going to radio-shack and buying their wiring-loom. it's this flexible, black, ribbed tube that you can stuff all your wires inside of. it comes it two different diameters...if you're using thicker cabling you'll definitely need the thicker loom. i think they're about 6ft each...but not sure.
    in addition, get yourself some of the black reusable zip-tie cords. they'll come in handy to wrap up the excess wire around or behind the components.
    in my case, it took me forever to get it done, but i'm pretty happy with the results.
  3. efren
    efren Auditioning
    Feb 21, 2002
    12
    I've used wire looms you can get from AutoZone. It comes in different sizes, really easy to put on and take off. Also get plastic ties while you're there... [​IMG]
  4. John_KC
    John_KC Auditioning
    Jan 31, 2001
    4
    Do these come in different colors?
    Thx
  5. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    It helps to put your amp/receiver on the BOTTOM shelf. This allows the speaker wires to flow out with minimal drop, and the wires wont obscure the rest of the equipment. It also helps hide the speaker wires.
    Pick a side and run your power cords to one side of your rack. Bundle them with velcro wraps or even nylon ties (Check your local hardware store. You'd be suprised at what they have).
    Let the interconnects flow down the middle of the rack. Use the split-loom tubing, or velcro ties to hold them loosly together.
  6. Andrew V
    Andrew V Stunt Coordinator
    May 11, 2000
    197
    There was a thread not too long ago by HTF member Michael Lee. He posted some pictures of what his equipment looks like both before and after cable management. The change is really stunning. Check his thread out here: Cable Management = Happy Spouse
  7. paul watkins
    paul watkins Stunt Coordinator
    Feb 22, 2002
    84
    in reply to colors,here in wilmington we have a boaters world,they have the flex tube in white,black,red,green,up to 1" diameter.
    paul's HT
  8. Jerry Wright
    Jerry Wright Agent
    Feb 15, 2002
    44
    John, I bought my wiring loom online at Radio Shack and there it is sold by the foot, both the 5/8" and the 3/4"
  9. Phill O
    Phill O Stunt Coordinator
    Mar 11, 2001
    128
    Now that I am working for a funiture builder. I am going
    to make a AV cabnet with casters, 17" shelves and 5" more
    of over hang on the top and sides. That way when I push
    the cabnet against the wall all the wires will be hidden.
    I will post pictures when I finally get off my duff and
    compleat this project. Thats my idea of cable management,
    hide them.
  10. Larry Cole
    Larry Cole Auditioning
    Jan 30, 2002
    6
    Most of you have probably been doing something like this all along, but I finally got smart and bought a bunch of those little tags on string (like for pricing, from Office Max) and labeled both ends of every wire. Makes life a lot easier when I pull some component and a couple wires pull off the back. I used a CAD program to do a schematic too.
