Cable Installation (1 Viewer)
Duanec60
Craig
Help! My home theater system is severely impacted by poor cable connections. I want to solve this once and for all. I need to bring the cable line into the house and split 3-4 times for various units spread throughout the house. Are there any guides on this website for making
these connections?
I have no issues with the rest of my HT system it's just a problem with the cable signal.
If a professional was to install my cable, what equipment would they buy to make the physical connections?
Robert_J
Mississippi
Compression fitting F-connectors and compression tool. Also get a coax stripper. It turns the stipping from a 30 minute ordeal to get correct to a 5 second breeze.
How do you know it is the connectors? Has the cable company tested the signal coming into the house and shown you that it is adequate strength?
-Robert
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Yeah, watch out for too many splits. Probably not "proper cable protocol," but I did a two-way split and sent one of those feeds to the location I cared the most about and wanted the best-quality signal - the main system. The other feed I split again and send those to the places I cared less about - the bedrooms.
Wayne A. Pflughaupt
Jquick80
