cable help?
Discussion in 'Accessories, Cables, and Remotes' started by Frank joe, Jul 27, 2003.
  1. Frank joe
    Frank joe Stunt Coordinator
    May 28, 2002
    155
    hi, i need some decent cables without breaking the bank. i have jsut purchased a ati 250watt per 5 channel amp. so i need 5 cables . were should i look and do i stay away from monster????????????? also anyone ever hear of diamond backs?>>????????????// help thankyou frank
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    Usually the best bang-for-the-buck are cables from the custom cable sites.
    Since you are dealing with audio, you can buy 2 component video cable sets (3 wires in each) and use these to help reduce "cable clutter".
    If you are trying to stay under a budget, the AR brand of cables or even the Radio Shack "MegaCable" cables have a good representation for video. They should perform well for audio as well.
  3. Jon_Welker
    Jon_Welker Second Unit
    Apr 29, 2003
    404
    I think the diamondbacks are a product made by Audioquest (www.audioquest.com). Audioquest makes a full line of audio & video cables, speaker wire, etc. Their stuff is supposedly pretty good, but it's not cheap either. Check their website for products.
  4. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    I take it that's to go between your receiver or preamp and the amp. Set a price limit for yourself and search out the lowest capacitance/ft cable you can find that's reasonably well shielded.
  5. Vincent_S
    Vincent_S Second Unit
    Nov 29, 2002
    450
  6. Frank joe
    May 28, 2002
    155
    well, thanks for all the help. i selected to go with straight wire cables . while they are not cheap i am only going to need 1 meter cables. i selected the encore line 5 channel cable ( 5 seperate cables in on mesh sleve) . i also selected a digital coxial cable called megalink. also 1 meter . i dont have far to go as i use a bello audio rack. i purchased both for 254.00$ delivered from an internet site. (offical site for straight wire) .
    frankie
