Cable distance question
Discussion in 'Accessories, Cables, and Remotes' started by Sam P, Feb 10, 2004.
  1. Sam P
    Sam P Auditioning
    Jan 26, 2004
    8
    Hello to all,
    I have a cable distance question. I just purchased a new wide screen HD Tv last week and i need to relocate all my audio equiment. What is the recommended max distance that i can run my video component cables and audio cable between my amp and tv without loosing too much signal.
    Sam
  2. MikeTz
    MikeTz Stunt Coordinator
    Mar 7, 2003
    146
    I run a 35 foot component cable with no problem. I've heard people say that 50 foot lengths also work.
    Balanced audio cables can be run over 100 feet with no issue. Single ended RCA type audio cable should be kept as short as possible (3 or 4 meters is OK). But I have heard installations that have 30/40 foot single ended cables that still sounded good.
    MT
  3. JasonMilch
    JasonMilch Extra
    Jan 21, 2004
    24
    Keep them as short as possible but unless you're over 100 feet, you shouldn't notice any dgradation
