Cable Connectors Question?
Discussion in 'Archived Threads 2001-2004' started by Chris Will, Jan 29, 2003.
  1. Chris Will
    Chris Will Screenwriter
    Jan 7, 2003
    1,056
    269
    1,610
    Montgomery, AL
    Chris WIlliams
  2. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    Chris,
    it's easy -- use wire cutters to lop off the pins. Carefully cut the insulation about one-HALF inch back. Twist the strands tightly/neatly. Insert stranded wire into new banana plug.
    Some bananas require that once the wire is inside the barrel, you fold the strands back down -- splay them out here -- and then screw the pieces together. If the banana plug come with plastic sleeves, be sure to slide these first down the bare wires.
    bill
