Arron H
- Jan 17, 2002
I have the speakers on the TV off and set to fixed audio out so that the volume for my system is controlled via the receiver. However, there is also volume control via the cable box that I cannot find a way to bypass. I have the volume on the cable box turned all the way up. I then use the volume on the receiver to adjust volume up and down. Does anyone have an opinion on where to set the volume on a non bypassable cable box?
